My buggy has a slightly worked jeep 4.0 motor. Given that I don't have much use for the air compressor, it's time to replace the serpentine belt, and I'm one of those guys that cuts 5-8 lbs every time he gets a chance I thought I'd get rid of it.
The trouble is, I'm not sure if I can. I haven't had much engine trouble so I'm weaker in that area than I'd like to be.
Here's a diagram of the normal routing for my accessory pack.
The top left pulley is the air compressor. If I remove it and run over the top of the idler pulley the wrong side of the belt will touch and the pulley will spin in the other direction. Are those things ok? Is the idea of removing the air compressor going to work?
Where's the belt tensioner in these diagrams? I worked with belt drives for a few years, and heard the term idler and tensioner used interchangeably, but they're not. A true idler can be rotated backwards, but if that idler pulley is on the tensioner arm, you don't want to reverse that direction.
The idler pictured should be a smooth one, designed for the backside of the belt. It will be OK running backwards (if its not the tensioner) with the belt ribs riding on the smooth idler pulley. My only reservations would be belt tracking, and those span lengths look fairly long. I doubt this idler pulley has a "fence" on the font or back of the pulley to help keep the belt on, most likely its just a radius. Then you'll have to figure out the new belt length.
When I first read this post, I thought the best thing would be to relocate the alternator to the AC position. Most likely some bracket/fab work, then still need to figure out the new belt length.
The diagram cj777 posted shows the WP and fan spinning the opposite direction from what you have...thats not gonna work. Maybe with an electric fan, but do you want to reverse the water pump flow?
For figuring belt lengths, I've gone to
http://www.daycoproducts.com/, then,
APPLICATION/INTERCHANGE, then in the new window
Poly-Cog Belts. Enter the # of ribs and your measured belt length, it will spit out a Dayco #. Cross this on napaonline.com, see whats in stock, how much....it sure beats the genius at AutoZone asking 2 or 4 wd...?
EDIT: it seems like either Dayco's database or my Firefox is acting up, I keep getting the same results no matter what I search on.
One more thing...if the belt length you need is only available in something too wide, don't be afraid to use a razor to remove a few ribs.
