shocker998md
- Mar 6, 2007
- grantsboro nc
Hey guys,
I'm doing some Thanksgiving sit back, think and make a troubleshooting plan and could use some advice. I'm working on a 1997 cherokee 4.0
The original engine had a piston come apart so I found a 98 cherokee and snagged its engine. I freshend the head up, did a leak down, checked bearings, and put a new oil pump and timing chain in. I know for a fact the cam and crank sprocket dots lined up.
I just got everything buttoned up and started it yesterday and it has a horrible miss. High idle most of the time, breaks up when given throttle, is a pain to start and has a 1391 code. Now thinking about it there could be a possibility that the crank sensor got damaged on engine install.
I wouldn't think the distributor would have gotten damaged when the original engine took a dump but who knows. But if these are stabbed one tooth off can everything adjust enough for it to barely run?
I'm thinking check number 1 at tdc and where the rotor is pointing, then make sure grounds are good. Then from there test sensors. I dont really want to just throw parts at it but I'm not experienced with troubleshooting sensors on the 4.0
Anyone have any advice?
