- Mar 13, 2005
- Raleigh, NC
The Jeep in question is a 98 TJ, 4cyl, mostly stock electrical system, aside from a Sears/Odyssey AGM battery (group 34, 135 min reserve capacity), some two-way radios, and a Warn 8274. Battery connections are the 'military-style' terminals like these:
Each major battery connection (winch, chassis electrical, etc) is on its own side of the terminal, so there's less chance that the winch connection could get hot and cause an open at the chassis connection, etc.
So, long story short, here's the gist of it: Fairly hard winch pull, engine is running at about 2k rpm, we'd been taking breaks to let the winch motor and alternator cool. The log we were dragging got momentarily hung up, the winch bogged down a bit, and the voltmeter in the dash immediately dropped to the peg (less than 9V). Check engine light came on. Engine is still running, winch still pulling, radios still working, cluster still lit up.
Shut it down, checked everything out, nothing seemed amiss. Fired the engine back up, and we're normal again.
My thinking is that if the alternator crapped out (or fusible link opened/connection got hot and opened, etc), the volts should have dropped to 12V or so, and the ALT light (assuming there is one) would have come on.
Could it have been a bad connection between the battery and the chassis power? The alternator kept the engine running, but couldn't see the battery anymore...? I'd think that the alternator field would collapse without a reference voltage, in which case the engine should have quit... but maybe not?
From what little I know about Chrysler Jeeps, they're second only to mid-century British cars for weird electrical problems. But I figured I'd throw this one out there in case anybody has any good ideas on what the source of the problem might be.
