motobilt
- Jul 25, 2013
- Dothan, AL
Jeep JK 52" Light bar mounts at Motobilt.com
The Jeep JK 52" LED Light Bar Mount System from Motobilt was designed with function and form in mind. Often time people are puzzled on where to run the wires for the light bar and hide them from sight. When designing this bracket system this was addressed. We spaced the mounts out slightly to allow room for the wiring harness to pass behind the brackets. We do not provide wiring instructions for the LED light bar. The brackets are laser cut from 3/16" steel plate and formed on a hydraulic press brake. They not only provde a solid mounting point for your LED light bar they also provide protection for the a-pillars of the windshield frame.
Our Jeep JK 52 inch LED Light Bar Mount only comes in contact with the windshield mount at the base. They do not come in contact with the windshield frame and a rubber gasket is not needed. The light bar mounts are shipped bare steel for you to paint or powercoat. We ship them this way because so many people want to color match their Jeep JK.
THIS LIGHT BAR MOUNT IS DESIGNED FOR LIGHT BARS MEASURING 52" AT THE MOUNTING WIDTH. This mounting bracket kit can be used with the Lifetime LED 52" Double Row or other LED light bars measuring 52 inches such as the cheap Eyourlife LED 52 inch
FEATURES
Laser cut 3/16" steel plate
Designed for LED lights with a mounting width of 52" wide
has room to run wiring harness behind the bracket
Keeps the top of the LED light bar below the roof line for a tight fit
Includes hardware
LED LIGHTING IS FOR OFF-ROAD USE ONLY
FEATURES
Includes hardware
