mbalbritton
- Mar 22, 2005
- Lakeland, FL
Bought my kid an '03 Liberty 2WD. Front tires were worn bald on the Inside edges and the steering was squirrely as shit so I knew it needed an alignment to start. Dropped some new tires on the front and had an alignment done and now it drives MUCH better. however I noticed that when it returns to center, it returns about 95% the way from either direction. It does not finish the last little bit and leaves you in a slight turn that you have to correct. Returns from Left and leaves you at a slight left turn, returns from right and leaves you in a slight right turn. One last bit of info of anything that I can think of that might effect steering (but I don't think this is it), the Front tires are slightly larger than the rear tires. the PO put 235 on the back, I put 245 on the front.
Before I take this thing back to the service shop, could there be something else with the vehicle causing this issue assuming that it's aligned properly? I do think they were in a hurry to align it at the end of the day. May just be a bad alignment job.
