ProfenderUSA
profendersuspension.com
- Apr 25, 2011
- Canandaigua NY
Lifted Jeeps need a steering damper to control front-end shimmy and/or wide tires that often seem to have a mind of their own, especially on back roads. The Profender RTC steering damper acts as a stabilizer and helps to return your steering wheel to the center.
The coil-over design helps keep the steering centered; no matter the road surface or terrain. When compressed, the spring pushes back to the neutral position. When extended, the spring pulls back to the neutral position.
Fits XJ ZJ TJ YJ stock steering
