Jeep sputters on startup and multiple OBD codes
pinecone73
Eastern NC
Hey everyone. When I first got my Jeep in February (2012 Sport Unlimited), it had a CEL shortly after leaving the dealership. They took it back and noted that the battery terminal was loose. They drove it for a while to make sure it was good and gave it back.
I was driving it off and on since then and it ran great. Then the other morning I went to crank it up and it sputtered, the CEL came on and another light which I found out was the Electronic throttle light. A guy comes over tonight with his OBD reader and found the following codes:
P0200 Injector Circuit Open #2
P0206 Injector Circuit Open #6
P2302 Ignition Coil A Secondary Circuit
P2305 Ignition Coil B Secondary Circuit
P2311 Ignition Coil D Secondary Circuit
P2317 Ignition Coil F Secondary Circuit
Definitely something going on and just wondering if there may be a single item to look at? Thanks for you help on this!
