Jeep TJ Axles. 4.56 gears, Locked, d30/d44 SOLD
ihaterice
raleigh (ncsu) NC
Factory Jeep axles out of a 2000 wrangler TJ. Front axle is Low pinion Dana 30 front and rear is the Dana 44.
Front is complete hub to hub, no brakes, rear is complete drum to drum.
Axles have been regeared to 4.56, and have an Aussie locker rear and a lock right locker in the front.
Axles are dirty, but are from a southern Jeep, no rust.
Rear axle has a truss and triangulated upper control arm mounts, stock upper mounts and trac bar mount are gone, all other TJ stock mounts are there.
Axles were just taken out of the jeep recently and work fine, only issue is the rear axle pinion bearings are starting to wear out and rear pinion has play in it. Gears are still good but will need new pinion bearings eventually.
SOLD
ihaterice
raleigh (ncsu) NC
Open to offers. If you think I'm too high, let me know and we can try to make a deal!
