Estonian
Member
- Oct 25, 2008
- Raleigh/Garner
i just got my 8.8 back from ECGS and am ready to install it in my TJ with the rear adjustable upper and lower control arms from Ironman4x4 in Boone NC. I need to know what the starting lenghts should be for the control arms to have it somewhat close to what it should be to drive good... should i just measure the stock arms and and adjust the new arms to the stock arm lenghts? ( i am running a 3.5 RE lift with a 1" BL ,1" Motor mount lift, with 33 MT/R's, SYE, tom woods drive shaft). And is there anything else i should look into or be aware of about the control arms? Also the lower arms have the heim joints on the frame side of the jeep and poly bushings on the axle side, and bushing/bushing on the upper arms. thank you.
