98zjstroker
- Oct 14, 2009
- concord nc
Ok so I installed my stroker motor the other day and tried to bolt the torque converter to the flexplate. As I turn the crank to line up the bolts the torque converter moves as well due to friction of it being up against the flexplate. After doing some research I found some say that the torque converter must not be seated in all the way.
I know that mine is in fact seated all the way. The first attempt to install the motor it wasn't which is how I know. I could not bolt the motor to the transmission because there was about a half inch gap. After pulling the motor back out I saw that the torque converter was not all the way seated. took it out and checked for damage.
I was very careful and didn't try and force anything. I reinstalled the torque converter and got it to align to all three things (felt the 3rd click) once I got it seated to the pump. It sat inside the bellhousing a good bit instead of flush with it like before. I felt behind the torque converter and there is not much space. any more and the torque converter would be hitting the actual inside of the bellhousing. The torque converter would also not go any further in at that point.
Then I reinstalled the motor. Got the motor and transmission bolted down. I tried to align everything up when I did and I am maybe 1/4-1/2 inch off from the bolt holes being lined up perfectly. Did some more looking and found that a lot of places talk about needing a space gap between the torque converter and flex plate before bolting it in for heat expansion. Its the stock original transmission and torque converter, with a different crankshaft (4.2l). Would that be the cause?
The things I have read that talk about the spacing says that if there is not enough spacing you can wear out the pump and/or damage the thrust bearing during the expansion because it puts more pressure on them. Should I be worried?
I was simply going to loosen up the bolts for the motor and transmission just enough to create a bit of space before rotating the crank the little bit I need to line up everything so I can get the torque converter bolts in. Is this a good idea?
