jeep turn signals pissing me off
Lee
ECGS
Louisburg NC
Ever since I did the CJ frontend swap I have been catching hell getting my front turn signals to work right. When ever I turn on one turnsignal they both flash in the front (still only 1 in the rear) and only the left signal indicator on the dash will light up, doesn't matter which siganl is on. I have ohmed out all the wiring from the bulkhead connector down to the wiring on the front end and the best I can tell everything is okay and wired correct. It is a 4 wire connector. (ground, marker and direction) what is the 4th wire? The turn signals worked fine with the old YJ light, I just cannot get the CJ lights to work correctly for the life of me.
Maybe you have a bad ground.
