GubNi
8 lug disc brakes?
- Mar 20, 2005
- Jonesborough, TN
Ok, my problem is I always forget to turn the headlights off unless it's dark. I need that chime so when it's daylight when I get to work I remember to turn the lights off.
I did some searches and found it's related to fuse 4. I installed that fuse and now the dome light works with the passenger door but not the driver door.
I pulled the door jamb switch and jumped in case it was a bad switch. Still no dome light.
I looked under the dash and found these two wires cut. I circled the connector that it goes to. The first connector has "26" on it and attaches to the side of the jeep with a bracket. The wire is light blue and white. The second connector has "40" on it adn the wire is much bigger than the others. It is black with white. This is in a 2004 TJ with 4.0 and manual trans.
Can anyone give me an ideal what these wires go to? Any ideals on why the drivers door doesn't make the dome light work? Any ideals on why the chime doesn't work for the headlights?
