cranbiz
- Nov 11, 2015
- Wentworth, NC
So at the meet and greet, I had a P0302 Cyl2 misfire and a P2305 cy2 2 secondary coil insufficient ionization. Rented a uhaul trailer and got it home. Found the #2 cyl coil pack bad with the internals coming up thru the epoxy. Changed it out and all seemed OK. Took it to Windrock Thursday and about 25 miles in, started again with the cyl 2 misfire. Ran fine at hiway speeds so I got to Windrock, pulled it apart and found the same mess with the #2 coil. Replaced it and the plug, and went wheeling Top of the mountain, same thing. Had other issues that may or may not happened due to this but anyways, I need ideas.
So, what could this be? I have been told that it could be the PCM. I have seen other people saying that they have had PCM issues cause similar issues with other cylinders. I have seen people say bad connections, say plugs, etc. @amcjeepman texted a friend Thursday night who said start with the plugs, but he had seen a similar problem on the hemi which was a bad PCM, causing the coil to fire constantly, overheating the coil. I'm leaning to getting a PCM due to my respect for James and his advice but just wanted to ask here to see if anyone else has seen this and can advise me if the PCM is the right way to go.
