JK Front Lower Control Arm Skids
Barnes 4wd
Etowah NC
If you are looking for the ultimate in protection for the front lower control arm mount on your Jeep Wrangler JK, you have found them with our JK front lower control arm skids. We start with our super strong Ultra 100 3/16” thick material, we then cut them out with the latest CNC laser technology, form them to exact specifications on a CNC press brake and it all happens right here in the USA! The Ultra 100 material is what sets our lower skids apart from our competitors, with a yield strength of 100,000 P.S.I. our skids are stronger than the competitions thicker material while remaining lighter at the same time, our Ultra 100 is also much more abrasion resistant than the mild steel that most other companies use, that means that you will slide over obstacles with ease and a have a skid that will last much longer. Not only will you have protection for your lower control arm suspension joints, this will add much needed reinforcement to you lower control arm mounts that hang low and are very susceptible to being bent or deformed when coming into contact with obstacles on the trail. If you want the best JK front lower control arm skids on the market you have come to the right place. You will receive one pair of skids, welding is required.
