joint seection for radius arm setup
jdubb
Gastonia
I'm new to radius arm setups. Is there a preferred type of joint used at the various end points? I see a lot of them with 2.63 wide bushings at the frame end. Thanks in advance. Lifting my daughter's LJ only concerned with street handling
I think most radius arms have a giant cartridge joint at the frame mount. So probably a ballistic joint or a Barnes enduro joint.
You could go with a heim if the Jeep doesn’t get a bunch of miles.
Usually rod end or flex joint at the frame and bushing at the axle, then for the upper arm a bushing and heim for pinion/castor adjustment.
