leaf spring hanger issues
fort bragg
Im building my yj up I got a 4" leaf spring kit and doing a spring over I installed the rear leaf springs and my springs are hitting my frame not sure if i put weight on them if they will straighten up or if i should make longer hangers any advice is welcomed thank you. its an inline 6 if theres any other info ill be more than happy to answer any questions
Maybe you can elaborate a little....what part of the spring is hitting the frame?...are your shackles inverted or somethin?
Also, I hafta question to wisdom of using 4" lift springs in a SOA configuration. Whacha need 9-10 inches of lift for?
