Leaking cooler problem
BigClay
Knower of useless ZJ things
Winston-Salem
So I think this is the right place to post this. I am looking for some tips and tricks to keep one of my large coolers from leaking out of the drain. I have the drain plug in it, but I guess over the years the plastic has constricted so there is not a lot of pressure around it, so water leaks out.
I am thinking about getting a rubber dish glove, cutting out a circle and then pushing that into the hole with the drain plug. Any other tips or tricks?
baby bottle nipple! plug it from the inside
If it is a name brand cooler you can order it online also hinges, latches.
ran into this last week packing for Harlan!! was gonna post just in case anybody else ran into this problem, i got one of those fit all rubber repair oil drain plugs, i wont use them on an oil pan but they work dang good on coolers and Advance auto had all sizes in the help section!!!!!! (for around a buck)
