Maybe it got lost in translation or you didn't look very hard.
-brake Cable Pull
The stock threaded rod on the cable pull isn't long enough to hold the cables so it needs to be lengthened. Oddly, I needed to shorten the original rod by about an inch in order for this to work correctly since otherwise the cable pull bracket interfered with the connecting nut. I grabbed a 4" section of 8mm threaded rod, a few nuts, a long connecting nut and some red threadlocker to create this:
Once the length had been worked out, I could add the cable pull and another nut to adjust the length.
Extended connector rod with cable pull
You can go to the link a few post above and look for the pics
