if your gonna wheel a zj decide first if you really like it cause its gonna be a real pita to get their. my setup is a 97 zj with 4.0,42re,231,xj hp 30,chromo shafts,aussie locker,trussed,explorer 8.8 rear,31 spline shafts,welded tubes,aussie locker,488 gears,custom 4 links front and rear(I DO NOT RECOMEND ANY LONG ARM KIT THAT HAS A RADIUS ARM FRONT)6 in springs,custom skids, bumpers and 8k winch. and 35-12.50-15 xterrains. i have wheeled it for 3 years in its current state and it still impresses the hell out of everyone with near vertical climbing ability at 114" wb. it will flex over trenches or car sized rocks and the body stay level never lifting a tire. however if i were to do it again id left it on 33's and done axle swaps. as for a lift i suggest the new rough country 4 in kit. they got a bad rap for their crap control arms but now they have changed the links and started using a flex joint. get a good track bar with a heim on one end (not rustys)also look into a heavy tie rod. the zj is a great platform but its heavy ,the unibody will start poping at the seams no matter how much you reinforce it and my problem is now i am limited to trying to not bust the glass in the rear when i get in a tight spot. so theirs my 2 cent good luck and if you need a set of bumpers im selling mine.
