11 year bump
Barnes three link tube package they sell has a 1.75" OD 0.125" wall. Am I being paranoid about wanting to get a larger tube? Upper link eye to eye is roughly 43"
That'll be fine. Just don't buy it from barnes unless you want to spend a shit ton. Race City will cut to length and ship for way cheaper.
I'd also reach out to Andy at Ironman4x4 for an aluminum upper link. No welds, just threaded material.
11 year bump
I've always wondered if 6061 would hold up for upper links. I have quite a bit of scrap at work from time to time and would love to run some 1.5" 6061 uppers for my 7/8 heims.
Biggest thing is keep the jam nuts tight, you can pull threads much easier with aluminum.
6061 would be fine for uppers, the Savvy TJ 4 link kit uses 6061 on the uppers. Biggest thing is keep the jam nuts tight, you can pull threads much easier with aluminum.
I have contemplated this for a while.... Increasing the length and diameter of the threads should help with pullout. (thats what she said) I have thought about a bung/joint that would thread on the outside of the aluminum vs the inside, or something similar to above, but it clamps around and bolts through the aluminum and the link is entirely threaded into the steel bung.
Here we go:
2": https://www.mcmaster.com/60645k77
1.5": McMaster-Carr to save money on the uppers
You could also use a timesert or something similar so you have steel threads. Honestly though at that point you're really just looking for the bling factor or time=money means nothing anymore.
Here we go:
