carosemena
- Dec 3, 2006
- Charlotte, NC
Hey guys. I've been tossing around the issue of putting lockers in the front and back. I don't have the cash to put up the air lockers right now. When I do, I'd like to have new gears installed since whoever installing it will be in that area and I figured I'd get the most bang for my buck. I don't have a lot of cash, so i know I'll probably get one of those limited slip or Lock Right lockers. Should I install them in the front or the back first? What are the adv and disadv?
Thanks for your comments in advance.
Seen several other similar incidents also. Considering how awspence does on the trails I'd consider his advice. LOTS of times I see rigs with the front end over the obsticle, locker in the rear and both rears turning but not getting up. With both fronts turning and pulling instead of pushing from the rear it might make a difference. Either way, a locker is going to help your traction no matter which end you put it in
