Looking for nc4x4 vendor for d300 parts
99ncxj
Aliso Viejo, CA
I'm looking for a vendor that can sell me some seals and shims for a d300.
Anyone?
Call Chase or Ryan at ECGS. We should have the rebuild kit. Not sure if we can supply just shims but he can check.
last time i talked to chase, he couldnt get any of the shims for a 300. Ended up cutting my own out of some shim stock for the front output, and mcmaster sells an assorted thickness set that the ID and OD will work on the rear output.
I've got a few shift rod seals if you need, I bought some extras on the last project. They are only bucks from quadratec though. Which shims do you need, for the yoke, or for the front output bearing preload?
Bearing preload, but I put it back together with two of the three that I pulled out and the preload is right now.
Just need two output seals now. I'll get up with you matt and see what you have
