Let me start by saying I'm a Ford guy so everything LS is new to me. I have a new to me buggy with a LQ9 6.0 that is using an OEM ECM and stand-alone harness. It's a mild build, stock bottom end, BTR cam, F body intake, drive by wire, & MAF. Not a fan of DBW and I know the is an issue with the MAF (MAF voltage too high code). Already swapped out the MAF and it's not the issue so it's the harness or ECU. I also prefer speed density over MAF strategies. I understand the reliabilities of the OEM ECU and they seem like a popular choice for LS swaps. I need to be able to tune and make adjustments myself. It has a TH400 trans so no TCM needed.
So that brings up the following options:
1) OEM ECU with HP Tuners
2) Holley Terminator
3) FiTech (I see mixed reviews)
What say you and your experiences?
