Jalopyjk
Member
- Nov 13, 2020
- Cliffside NC
I have a almost complete LS swap for a jeep jk, it’s a 2004 lq9, BTR truck Norris cam, completely rebuilt 4l80e, Holley terminator max x, 6.86 touch screen, bruiser motor mounts. I’ll list everything I’ve bought and this is just what I have in it, plus my time and travel. Looking for around $10,000, I have close to 13, I’m sure I’ve missed some things too. Looking for a bunkhouse camper is the reason I’m selling and sold my jeep.
Novak adapter-$647.27
Bruiser mounts $502.00
4l80e rebuild $2,000
Reversion racework dash- $215
Btr cam kit- $510
Cold case radiator- $519.12
Engine/trans- $1800
New pistons and rods with cam install- $700
New Rocker arms- $204
Valve spring assembly $200
Winters shifter $300
Holley terminator x max with 6.86- $2,482
Crank sensor- $48
Oil pressure sensor -$30
Coolant temp sensor- $16
Intake gasket $20
Cam thrust retainer plate with arp- $40
Ict billet coil brackets- $46
Ict billet valley cover - $45
Ls7 lifters- $135
Fel pro head bolts- $80
Fel pro head gaskets- $79
Fel pro timing cover set- $33
Scott Performance spark plug wires $120.98
Melling oil pump and timing chain- $155
Bbk 1/34 short headers- $405
102mm intake and tb with rails- $410
Stainless coolant crossover $38
Alternator $176.79
Water pump $121.79
Starter $143.79
Goat built bracket $206.95
$12,447.68
Btr cam kit- $510
Engine/trans- $1800
Crank sensor- $48
Intake gasket $20
Ls7 lifters- $135
Alternator $176.79
Water pump $121.79
Starter $143.79
$12,447.68
