TRC&P25
- Jul 6, 2008
- kannapolis
need to get my block bored and other stuff, and maybe head work.
thanks for any help!
Just had some Machine work done to a 22re bottom end up here is Salisbury. There is a small autoparts store/machine shop that does good work at a fair price.
Rouzers Auto
I had them bore the cylinder 40 over, they had to turn and polish the main and rod surfaces on the crank, fix the connection rod end (resize them to spec), hot dip the block, install the new freeze plugs and press the new pistons on the connection rods for less than $300.
They would be a good choice for anything like that. DOA would probably be better for the specilized head work if you are going all out and have the money. Rouzers does head work, i just didnt need any at the time. (Fairly new head)
Hope that helps....
Seth
