336wheeler
- Sep 9, 2006
- Boone
Running a double CV driveshaft from an explorer (kevin correct me if I'm wrong on that), and on the axle end it used the external full circle snap rings on the u-joint. My D60 front yoke isn't the style that has the two cast-in pins that hold the u-joint in place, and I haven't been able to find one like that either. It uses the internal snaps. Ideas for that?
Also, the transfer case end (CV yoke) uses a different bolt size that the transfer case yoke. Is it best to drill and tap the transfer case yoke? Seems like this would compromise strength a fair amount, although the bolt sizes aren't too much off.
