I've researched this alittle. From what I've seen, in the long run, you'll be better off to pony up and get a good built auto. For around $4000, you can have Brian's Truck Shop build you a tranny that you won't have to worry about. If you swapped, once you put an upgraded clutch with it, and all the headaches of the swap, you'd be pretty close to that figure.
