metric size= 31" tire!
Trailmaster C
Roxboro N.C.
SORRY PUT IN WRONG PLACE!!!I have found some 16" wheels not sure what size metric tire is close to a 31X10.50 any help?
Thanks,
Bradley C
Ok here is the info you need to convert.
1 inch = 25.4 mm
Metric tire size are given in teh formula
width/aspect ratio/rim size
So
a 235/75r15
is 235 mm wide
each side wall is .75x235
and the rim size is 15"
In this case you want a 31"
and have a 16" rim so you need 15" of sidewall.
For ease lets divide that by 2 or 7.5" per sidewall
Now lets convert that
7.5 x 25.4 = 190.5mm
In this case for a .75 you will need a 255 (253.3)
For a .70 a 275
Or for a .65 a 295
All that said this chart will help also
http://www.thefosterfamily.org/4x4/tires.html
and here is a calculator for the math if you are lazy
http://www.4lo.com/calc/gearmetric.htm
SkyHi gave you everything you need, sometimes I go to a site like tirerack.com and if you look at a list of tires, they will show the O.D. (Overall Diameter) of the tire. It's very helpful since 2 tires with the same size by different companies will come up different heights.
Also, it helps just looking at the O.D. if you are willing to got wider or more narrow on width just for the right height.
Is there any specail raeson why someone might want to go wit 31/10.5 over a 255/70? Everyone had been telling my to go with the 31s on my XJ but when I went to the store the salesman wanted to seel me 255/70-15. He said that they would give me the width of the 31 with the hight of the 235/75-15s that I'm running now. I don't need more clearance, just more width & I'd like to do it without putting in a lift.
