My 88/97 XJ Build
1 Ton Steering and New Adj. Trac Bar
H4 E Code 200mm Housing
Thats all for now. Right now im working on a game plan on what to do next. 4:56's coming up along with a Lunchbox locker of some sort for the 30. Got some Skids that need to be put on along with some sliders.
Now i know this is not an extensive build. I am still learning and being a broke college kid doesn't help. I try to do what i can with what I have. I have learned alot from you guys on here and hope I can build something that I am proud of. More to come as things change. Thanks for looking.
Absolutely nothing wrong with what you have. I believe in "run what ya brung" is a lot better than web wheelin any day!
I read in another thread that you didnt like the 1 Ton steering, something about tie rod roll...whats that all about?
Its a strong system, but the roll that the tie rod has is not as bad as people put it out to be, but it still sucks. Its not dangerous or deathly frighting, it's just different. I would just much rather have the inverted Y setup instead of the inverted T setup. I should also probably throw a spacer on both TRE's to see if that helps but not sure I want to mess with it.
