My trans takes a leak on really steep inclines...
spraypaintman
Greensboro
Only when I'm on really steep inclines it leaks auto trans fluid pretty bad. It is the TF727 auto trans from a wagoneer. Is there some sort of vent or overflow hole that needs a breather line hooked to it?
the overflow is on top of the bellhousing. On the rear tailcone, from underneath, look up in between the lower two vanes, there is a port hole there(pretty small hole), plug it w/ some jb weld or drill and tap it and run a vent line.
Is the hole on the bottom of the t-case adapter?
I saw your zuki project out there and talked to the owner. The red one with coil overs and 10 bolt axles. Looked nice...his buddy rolled his zuki on daniel twice! LOL
