Need coilovers charged
If there is a welding supply store nearby, the'll usually do it on the cheap. Alot of those places run Nitrogen in their tires on the work trucks, so they have the setup to do shocks.
Just an idea.
Most of them won't be able to do the kind of pressure you are looking for though.
Do you have a 4wheelparts near you? They do it.
Don't C/Os get 200 psi? Most of the Nitrogen regulators ive seen in the supply shop around here are 50-500 psi, 0-50 cfm regulators.
One of the places with the "Nitrogen in your tires" stores won't be able to reach higher pressures though.
find your closest andyoxy They supply your area.
You should be able to get them to take care of it.
A
You can also try local dirt bike shops. Most of them can charge them no problems.
pm sent
