Jones4WD
- Mar 21, 2005
- Wake Forest, NC
I am in the middle of rotating my rear axle on my 96 Jimmy to put the pinion in line with the new cv driveshaft. My problem is the truck was originally a SUA and the trailmaster lift lifted the rear by doing a SOA. To do this they used spring perches that fit on top of the axle and have little feet that sit in the cups of the original perches that are on the bottom of the axle. To start off I marked where the SOA perches were currently located and then cut off the old SUA perches. I have the perches on the axle and loosely u bolted together so that I can set the pinion angle. The problem is I have the perches lined up with the marks I made earlier and the axle seems to be off to one side a little. I measured from the pinion to edge of leaf springs on each side and got about a 3/4" difference. Should I set the perches based on the measurements or on the marks of where they were before? I mean the marks should be right but its hard to measure (no good reference points). What would happen if the axle ended up being slightly off to one side? Would being slightly offset affect the driving. This is my DD so I need to to be very streetable. Thanks for any help, I can't afford to screw up my DD.
