nc4x4dude
Member
- Mar 31, 2007
- Wilmington
I have a 67 M715 with a Mopar 440. It is push button start. When I push the button to start it cranks up but when I let go of the button it dies. If I push the button and hold it, it stays running but the starter keeps turning with the bendix not engaged though. The push button has 2 wires, one to its own 20 amp fuse and the other goes to the solenoid. All fuses are fine and all wiring appears to be intact. Could it be the solenoid? Everything is wired on a panel and has its own fuse. There is a toggle for the ignition which comes on when flipped, it runs to a seperate solenoid. Any help or suggestions would be great. Thanks, James
