Pros: Motor has lots of low end torque and provides for a light weight rig, two less plugs to buy for tune up, usually come with 4:10 gears in the axles, 95 is the sequential multi port fuel injection with external slave cylinder for the clutch
Cons: Motor does not have enough power to turn larger than 33" tires at highway speeds (5th gear will be useless with large tires), AX5 is a weak link when adding larger tires and rough use, transfer case is weaker 21 spline input compared to 23 spline 4.0 input, fuel mileage will be similar to a 4.0 not a gas guzzler, D35 rear axle shafts will not stand up to abuse with 33" and larger tires and c clip axle shaft retention design can present problems if you break a shaft, square headlights (subjective)
IMO a 95 2.5L is a nice option for someone who wants to have a Wrangler, is not concerned about fuel economy, is content to do mild off road trails and intends to run 33" or smaller tires.
