Need nissan frontier advice
snappy
YHDG's adopted son!!!
Moderator
high point
Just picked up an 03 crew cab Frontier. Wanting to do small lift and 31-10.50 or 33-10.50 on it. Whats the go to for lifts? And no i am not going to straight axle it(for now)…..
Not a lift answer, but of it hasn't been done (and it is an automatic) to avoid "SMOD" aka, strawberry milkshake of death, be sure to replace the transmission cooler (radiator) or bypass it with an aftermarket cooler.
A body lift will get you what you want. 4x4parts is where I'd buy a lift if you go that way calmini has had issues with sending parts out.
I had a 01 with the body lift. And a 99 with a 4x4parts lift both were on 31s
AFAIK, this only applies to '05+. What @Loganwayne said, 4x4parts.com. Good people, good stuff.
limited stuff for an 03 I see.
I was going to say the same. Had a Nissan extended cab years ago and there wasn’t much in the way of good suspension lifts available. About the only option was to add a block to the rear and crank on the torsion bars. Maybe things have changed.
