97 Chevy, 2500HD, 5.7. 4L80E, A/T, 2wd 183K
recent tuneup with plugs wires, cap, button,. Still runs like crap at idle and up to 2000 rpm. Had the codes ran at Autozone and and had two come up, P0172
Definition:
Fuel trim bank one condition
Explanation:
The powertrain control module use the O2 sensor to calculate the Air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
Probable cause:
1.If bank one and two codes set together suspect fuel pressure or MAF Sensor
2. O2 sensor defective
3. Ignition Misfire-repair
4. Fuel Injector problem
And then code PO175
Fuel bank two condition
ECM has detected a rich or lean condition on bank two
Cause;
1. Suspect fuel pressure or MAF
2. Failed H02821 (heated O2 sensor) bank 2
3. Injector problem
4. Engine Mechanical condition.
I have gauges to check fuel pressure and will do that in the morning.
Its been stumbling at low idle for a long time. I've replaced all O2 sensors before but it's been 75k ago. I read about the distributors having a plastic part that wears out and causes this issue. I replaced the fuel injectors (spider) was what they called it at about 75k.
The cats are gutted.
I don't have money to throw parts at it. I can switch out the MAF with another truck I have to check it.
Any help is appreciated.
RQ
Definition:
Explanation:
Probable cause:
And then code PO175
Cause;
3. Injector problem
RQ
