cumminsdzl
- Mar 20, 2005
- Wake Forest
2004 Dodge 2500 4x4 cummins, 183,000 miles.
About 3 weeks ago i had a friends shop replace my front axle ujoints. They had never been changed and had started to squeak when i turned so we went ahead and changed them. Probably a week went by and we had some snow one morning, so i used 4x4 for the first time since the new ujoints. When i first started moving i heard a little noise, kind of a rubbing, grinding kind of sound for just a few seconds and it was gone. No more noise for the rest of the drive to work.
Then this Sunday we had the big snow. I pulled out of the driveway, shifted into 4 high and immediately heard that same scraping, rubbing sort of noise. It reminds me of the sound your brakes make when the pads are gone, a metal to metal rubbing grinding sound. This time the sound didnt go away, it was here to stay.
I have found the noise is much louder when you are on the gas, very faint when coasting. I can very slightly hear the noise in 2wd also, but nothing close to like it is in 4wd. You can also feel a very slight vibration in the steering wheel.
Today the truck was back at my buddies shop for him to figure out what was up. They replaced the ujoints in the front driveshaft which were showing a little wear. This did not help at all. Drained the front diff, everything was good, no metal shavings, replaced the fluid. No play in the pinion bearing either.
I am starting to think the noise is coming from a problem with the new axle ujoints, i never heard this noise until we replaced them, it gets loud and has a little vibration when you accelerate like a ujoint going bad would, and is almost silent when you coast. Does this sound right to anyone? What about the front unit bearings, they are original, but seem fine, and they should make the same noise whether you are in 2wd or 4wd.
Sorry for the long post, just trying to get some ideas of what to check next.
