New Jeep Project
Discussion in 'Build Threads' started by yager, Jan 25, 2010.
  1. yager
    yager Better Faster Stronger
    Mar 17, 2005
    N. Raleigh, NC
    Yes I have the roll cage but will not be parting with it until I get the new one bent up.. No plans to start kinking tube for a while ~feb/march ish...
    Ya I started doing the prep work on the white tub but it started raining and said screw it.. Figured I'd start doing the things I new for sure needed to be done anyway... Before I knew it I was done...
    I'm just tired of not being able to make rides... Time to put the rubber to the road...
  2. rroadkilll
    rroadkilll Active Member
    Sep 4, 2010
    Hertford NC
    I may still be interested in it if I don't get one for THE HEEP!
  3. foreman1063
    foreman1063 Well-Known Member
    Jul 11, 2005
    Raleigh
    Hell Yeah! Me too.
  4. Black Bear
    Black Bear Well-Known Member Moderator
    Mar 21, 2005
    Raleigh, NC
    Damn Mike..
    If you need a hand, give me a shout.
  5. yager
    Mar 17, 2005
    N. Raleigh, NC
    Not much of an update but Zubs stopped by last night to lend a hand re-hanging the rear frame section in its new 2" higher position. Next up will be burning in the rear frame and tie plates and body mounts, then moving to the front end to wrap that up.
    I need to chase down a shipment from a vendor... :( update: Hey what do you know, its out for delivery... was ordered on 12/25.. so not too bad... Though I really need to find a stocking east coast vendor or manufacture.
  6. foreman1063
    Jul 11, 2005
    Raleigh
    Manufacturer of what?
  7. ScottR
    ScottR It's never done.
    Mar 21, 2005
    Raleigh, NC
    Mike- nice work on the rear floor/fender highline. Great work.
    Scott
  8. upnover
    upnover Grumpy, decrepit Old Man Moderator
    Mar 20, 2005
    Morganton NC
    Looking good Mike. I did see something like this once, a while back. Basically the guy had the top of his inner fender about an inch below the top rail of the tub. The outer wheelwell was maybe 2" from the top of the tub side. He had major room to stuff his tires and used it all with 42 TSL's
  9. drkelly
    drkelly Dipstick who put two vehicles on jack stands
    Mar 21, 2005
    Oak Ridge/Stokesdale, NC
    I like this build a lot. It should be a great trail rig. Looking forward to seeing it come together.
    Looks like you switched from the 36? TSL's to 37? BFG MT's?
  10. yager
    Mar 17, 2005
    N. Raleigh, NC
    Thanks ! Ya I'm getting excited the more I get done. I really like where this is going and am more attached to it now. I switched from the 36" TSL Radials to 35" KM2s radials. No real reason other than I felt the 35s were more streetable and they more/less fit the overall vision of the project better. To have a solid trail machine, minimize repair/breaks, get more DD use/seat time and generally get back to where I started.
  11. yager
    Mar 17, 2005
    N. Raleigh, NC
    Quick update...
    Pulled the rear floor section back a bit to finish cleaning up all the spot welds and sand/grind down all the seal sealer and junk.
    I pulled it all back into place and hit it with a few rivets to hold it together for now. I want to leave it removable in case I need access to the floor area near the B pillar foot area...
    Here are some pics while I had it out a bit. Just to more clearly show what the hell I was really doing :)
    I removed the leaf perches off the rear axle might get some brackets tacked on soon...
    Need to get the tub tightened up a bit before I moved back to the front frame to finish that up.
    anyway the pics of the tub.....
  12. yager
    Mar 17, 2005
    N. Raleigh, NC
    quick updates: will post pics later..
    Garage - Sealed the overhead door better along the edges using some 2" ratchet strap material, will detail later, but basically this hold up well and will hold shape against the door. So my door is sealed very well now.
    Installed 3" exhaust on lowrider DD pickup.. Drop install coming soon...
    Jeep -
    Tacked on rear lower link brackets, clamped on frame mounts. Measured/Checked clearance on axle <-> frame. I have ~7.5" clearance and am planning 7" up. So my flood mod planning and measuring actually was right..
    Started draping the wire harness back into the tub/dash area.. Found my old reference pics that I took from the 2 dollar whore beater parts jeep. Since its already painted, I can start laying that in.. Need to figure out the dash stuff... Want to make a large glove box using the former air bag location.
    Overall things slowly falling into place...
  13. yager
    Mar 17, 2005
    N. Raleigh, NC
    Quick update from last weekend and so far this week...
    I whipped up this cool hybrid starter for the 2.5L :flipoff2:
    It's basically a 4.0L motor on a 2.5L head. Just for reference the solenoids also were identical. No idea of the torque etc.. but bigger = better ! I know how much the 2.5L spontaneously stall out so I figured better starter be good. Yes it just clears the oil pan by ~1/4"
    Peak at the front frame rails. Have plenty of room for up travel and a my mounts for the struts don't have to be too high..
    Starting on the front cross tubes.. Will be integrated winch mount/fairlead
  14. yager
    Mar 17, 2005
    N. Raleigh, NC
    Engine
    This is where a fun begins......
    I've been researching small 4cyls with 20-40 hp over a stock motor with the potential to do a little more down the road. A wider power band would be nice also. I also wanted to stick with something with R series asin transmission compatibility so I could keep my toy tcase.
    I had considered the neon DOHC 2.4 (also in jeeps/liberty) and the older K-car SOHC motors. Both were available with a factory turbo setup and good aftermarket support. (compared to non with the jeep 2.5)
    Sooooo... I ultimately settled on a 2.2 ecotec. I started trying to locate one and ended up stumbled on an over priced mislabeled craigslist posting. I found a 2006 2.2 ecotec 42k on it. from an ION. I really had to contain my excitement as I was picking up my motor today.
    I'm still working how exactly I'm gonna make it run so I'm sure I'll be looking for help on those things. This little unit puts out
    140-150hp @5600 / 145-155ft/# @4000 stock with more with some basic mods. The peek numbers are at higher rpms but they more/less match a stock jeep motor but just go a bit higher. Plus it weighs ~300# and looks cool..
    I know these aren't the end all be all motor and have some issues. Most have fixes or work arounds and some I will figure out in my own creative way.
    Let the fun begin..[/B]
  15. iluv_mud
    iluv_mud Active Member
    Oct 23, 2007
    Asheville
    The ecotec is a great little motor when I worked at a Chevy dealer we had a caviler with the gm parts supercharger kit man did that car suprise me. IMHO I would consider that as a mod the car made good power had a broad powerband it became a torquey 4 cylinder.
  16. spraypaintman
    spraypaintman Well-Known Member
    Mar 21, 2005
    Greensboro
  17. yager
    Mar 17, 2005
    N. Raleigh, NC
    Heres where were are so far... need to work on finding a solstice/sky bell housing...
    Things will be tight but overall should fit..
  18. yager
    Mar 17, 2005
    N. Raleigh, NC
    Picked up a spare motor this past weekend, it came with this stuck to it..
    I'm only keeping the motor and some small items, the rest is going on to its new owner.
  19. yager
    Mar 17, 2005
    N. Raleigh, NC
    update:
    parts motor out,
    Ordered the Solstice/Sky bell housing to allow the AX15/R150 series transmission to bolt to the ecotec. Also ordered hex insert for the camshaft, this is needed to drive the steering pump that is direct drive bolted to the head.
    Picking up a R150 transmission today.
    still figuring out the t-case adaptor situation. Ideally I could bolt the toy gear drive t-case to the AX15 rear housing, using a toy output and coupler. But no one seems to make the adapter......yet...
    Have to see if there is a market for an adapter to mate a toy t-case to AX15/AX5.
    Got the rear cage/frame tie in pieces tacked in and bent of the tubes that will attach to that to hold the struts in the rear wheel well.
    Otherwise not much else.....
  20. foreman1063
    Jul 11, 2005
    Raleigh
    Don't get cheap on us now, put up some pics!
  21. yager
    Mar 17, 2005
    N. Raleigh, NC
    NO ! :flipoff2:
    and i got the R150 ! Nice meeting you Josh!
  22. muddin38yota
    muddin38yota Well-Known Member
    Apr 13, 2005
    Concord
    You too Mike, I like the build thus far..... I'll keep watching.
  23. yager
    Mar 17, 2005
    N. Raleigh, NC
    Got my solstice bell housing, bolted some parts together, still working on various pieces to the engine project.
    Flywheel be here this week..
    Looks like I'll be swapping in AX15 input into the R150 trans.
    Hopefully my t-case adapter be here this year...
  24. HANO
    HANO meh.
    Sep 16, 2006
    Myrtle Beach
    Looks good man and no selling this one until after that one important trip around April of next year.
  25. yager
    Mar 17, 2005
    N. Raleigh, NC
    ya seriously.... I've about had it with building stuff from scratch !!!
Share This Page
