- Mar 20, 2005
- Morganton NC
A good friend of mine has given me an old XJ. It is a 4.0 with a five speed. This is going to be for my son, who has limited budget, so a lot of this will be fabbed by us, and some stuff from KORE. He wants full width axles. We have a set of axles now, a 10 bolt and 12 bolt. I think will be heavy enough for what it will do, plan on 35 or 36" tires. Probably a used set of TSL's The problem is the front on the XJ is Drives drop and the 10 bolt is passenger drop. Having a shop re-tube the axles is not in the budget. Getting a 44 that is drivers drop and geared the same(4:56) is most likely out too. What I would like to do is cut and swap ends. I know it would be an undertaking. What I am thinking is to cut the tubes, and make a sleeve to slide in the tube, plug weld it in several paces, as well as weld the seam too. Taking great care to keep everything straight and not allowing it to deflect. Anyone here done this? Any reason it won't work? The outside would also be strengthened with the coil spring mounts that will have to be made.
If I do it, and it fails, I will be out time mostly. All input welcome.
