New tow pig
Discussion in 'Tow Rigs and Trailers' started by oscar80, Aug 9, 2017.
  1. oscar80
    oscar80 Well-Known Member
    Aug 23, 2009
    Sanford NC
    Yep I joined that site its great lol.
    I haven't decided yet if I want to cut the access hole in the cab or not
    Sent from my LG-H872 using Tapatalk
  2. zuke
    zuke Well-Known Member
    Sep 4, 2012
    Stafford, VA
    Personal opinion, I think the access hole from Cab to Module is of pretty limited value, And I'm assuming your cab has a bench seat in the second row, so that would limit it's value even more... I just have a small sliding window in mine, and most of the time I keep it closed (I Smoke in the cab, but not the module). When I have my pooches back there I do open it once in a while to check on them...
  3. oscar80
    Aug 23, 2009
    Sanford NC
    Bench seat was trashed so that is in the scrap pile.
    Option if I open was two chevy truck seats with an aisle in Between.
    If I keep it closed was going to put three chevy truck seats across the back or a fold down bench for extra sleeping room.
    Reason for seats is I have three kids. If I open it most likely they will ride in the back. If I keep it closed wife doesn't want kids back there by themselves
  4. zuke
    Sep 4, 2012
    Stafford, VA
    If you are going to let them ride all the way in the back, you'll need to provide some safe seating back there, if your module isn't already stripped out, you probably have seatbelts on the Crew bench, CPR chair, and attendant's seat now, but you'll probably strip most of those out when you refit with all the RV stuff you are going to want...
    The two seats and keeping the aisle open is probably a good idea if you want to let the kids sit all the way in the back, I'd also try and make at least one of the two second row seats swivel to the center if you can...
  5. oscar80
    Aug 23, 2009
    Sanford NC
    The module is still intact. Haven't done anything there yet. It is going to have the basics. Possibly bunk beds with bottom pull out couch. Bathroom in the Klan left rear area. Fridge were CPR seat is and microwave somewhere.
  6. oscar80
    Aug 23, 2009
    Sanford NC
    Just picked up a few of the interior parts from Marsh trucks in siler city That I needed. Man I came up with some more ideas. They had a few coke trucks with the overhead shelf that I am going to get.
  7. kaiser715
    kaiser715 Doing hard time
    Jun 1, 2006
    Pocket, NC
    I just now saw this thread, found it because I drove by your place for the first time in a long while (we usually come and go on Steel Bridge Rd). Saw the amberlamps out front of your shop....got right home and did a search on NC4x4 to see what you were up to. Nice plan....but you gotta get moving on it!
  8. oscar80
    Aug 23, 2009
    Sanford NC
    Lol I just saw your reply. I moved the truck since I started.
    Interior is gutted and painted. I ordered some sound heading and need to install that and carpet. Found an overhead console and the a pillar plastics.
    Dash is painted also.
  9. oscar80
    Aug 23, 2009
    Sanford NC
    Gotta touch up the dash a bit but a lot better than before[​IMG][​IMG]
  10. oscar80
    Aug 23, 2009
    Sanford NC
    Had to repair the battery box and I was too cheap to spend the 100 bucks for a used one so I cut bottom off and welded up an angle iron base[​IMG]
  11. Loganwayne
    Loganwayne #BTL
    Feb 15, 2013
    Clyde, North Carolina
    I really want to find a truck like yours and put a flat bed on it for hauling a rig
  12. oscar80
    Aug 23, 2009
    Sanford NC
    I looked for about 10 years on and off. All the ones I found were expensive or didn't have the right engine. I really wanted the cree cab also. Most I found had the t444 which I didn't want.
    I got this one for 4500 with the ambulance box. The interior was roached but I wanted to do the interior my way anyways.
    The engine wasn't exactly what I wanted. It's the dt408 vs dt466 or dt530. But it starts right up has the right fuel pump do it's good. Would like to build a dt530 sometime.
Share This Page
