leroycocke Member Joined Mar 19, 2012 Location Jonesborough, TN Apr 17, 2012 #1 How do i rem the "hub hole" big enough to fit a Toyota hub?
rattlecanpaint Well-Known Member Joined Apr 18, 2005 Location Winston Salem Apr 18, 2012 #2 If you want it to be hub centric like the factory wheel you'll have to take it to a machine shop. If you can settle for lug centric, a grinder will do.
leroycocke Member Joined Mar 19, 2012 Location Jonesborough, TN Apr 18, 2012 #3 Will i have to take the tires off
rattlecanpaint Well-Known Member Joined Apr 18, 2005 Location Winston Salem Apr 19, 2012 #5 Tire off the wheel? If you machine them yes, if you grind them no. Tire/wheel assembly off the truck? yes to both
leroycocke Member Joined Mar 19, 2012 Location Jonesborough, TN Apr 20, 2012 #6 Thank i would have never got that with out your h elp!
