Starting this week. I could use a shop recommendation near Cary.
The transmission has 187k miles. Fluid change within 5k miles (ATF+4) and level is fine now. Tuesday drove 7 hours through mountains and snow, in and out of 4x4 part-time the whole trip. Much of the time 45-50mph in 4th and no issues. Since Wednesday it will not get into 4th gear. 1st, 2nd, 3rd, shifts are normal, obvious and at the right speed. TC lockup occurs at ~35 as normal. I has been cold and there is now much road grime all over.
Where do I start to diagnose this?
There are no DTC trouble codes.
My thoughts: Not the shift-down cable since that would prevent TC Lockup.
Could be output speed sensor. Could be the govenor pressure sensor or govenor solenoid. Could be Overdrive Solenoid. This tranny has never been serviced other than me changing fluid (ATF+4) & filter periodically.
The OD off switch functions normally: maintains no higher than 3rd gear and disables TC Lockup. Overdrive Solenoid. "a 3-4 upshift occurs only when the Overdrive Solenoid is energized by an electrical signal from the powertrain control module." Manual is confusing in that it seems to refer to 4th gear and overdrive as the same gear.
