SHINTON
- Mar 17, 2005
- Triad area of NC
Ok, would like some feedback on my reasoning and logic, thoughts, suggestions, parts, vendors and so on!
88 Blazer, has auto tranny and NP208 transfer case, truck has 1.5" body lift on it and we know the linkage is off a bit because of that.
About a week ago I decided to test out 4wd, at this point I have put about 600 miles on the truck since I bought it a month or so ago. Keith had adjusted linkage a bit before I bought it, never a lick of trouble and he is on here as well and may chime in.
So I put in 4 Hi, 4 Low, confirmed it is all working good about a week ago, and then I have driven about 150 miles probably since then. Driving to work this morning as I came around curve on highway, ugly grinding sound (like a manual trying to mash into gear) for just a moment, stops, still driving ok. I am doing 55ish maybe and happens again say 30 seconds later and I start pulling over and by the time I am stopped I have "no power."
Originally I thought I lost the transmission, but worked through and figured out that if I put in 4 Low, truck will drive, shift all three gears (and do maybe 15-20 mph) Put tranny in neutral, tcase back in 2HI and put in gear and it drives again!! Drove on to work about 3 miles or so, several stops and starts, turns, etc.
Go to run an errand, came around curve into parking lot, no power (as if I am in neutral in tcase basically) but at this point I put tranny in neutral, (stopped moving also) 4 LOW and finished my errand to bank and then back up hill 1/4 mile to office.
Every time I have tranny in neutral and try to go from LOW back to 4 high / 2 high i get grinding. Turn engine off, tranny in park put in 2 hi / 4 high, start truck, shift to R N D and nothing as if tcase in neutral, try to put back into park and GRINDING noise!
So I think maybe a linkage issue, get under truck, manually move the rod between 2 HI and 4 HI, I can feel it moving solidly but still nothing, as if my HIGH range is not engaging at all.
Here is where I want to get some help / logic. I "don't think" I stripped the HIGH range gears / teeth mostly because if I had, could not have gotten back into HIGH and drove another 3 miles.
What I "think" is that there is something internal in tcase that "shifts" you into HIGH from Tcase neutral and that part is basically not engaging. I have done a tiny bit of research and shifter / forks has come up and I see a part.
I am hoping someone understand the internals of NP208 a bit more and might can explain in layman (does accounting for a living) terms. Basically what is the part that might be broke / not engaging?
http://www.drivetrain.com/images/stories/product_imgs_large/np208mw_large.jpg
I am guessing maybe part 31 or 35 in that picture is the fork and below is link to that part. I am guessing one of them is for HIGH and the other for LOW gear.
Transfer Case Repair Parts Online - NP208 Shift Forks
Rebuild Kits NP208 Transfer Case Parts Illustration and parts list, you save moneys! - Drivetrain
So, any help is appreciated. I am in Triad area, truck is in Greensboro, if there is local person you would recommend to diagnose and rebuild / fix it I would love to have a name and shop.
Another option is a 2nd NP208 I can pick up from Keith, works fine but leaks terribly. In theory I can buy a "gasket kit" for $25, but again need someone that can rebuild and swap out tcase? Tax season, busy and need it faster versus waiting on me. In this case would rather spend the money and get done since this is supposed to be my "winter" truck.
Thanks in advance for the help!
