your signature says you have a 241. unless you've swapped it out, you've actually got a 231HD. a 241 will bolt into place, and is probably the best "bang for your buck" option. the best thing you could put in would be an atlas or a stak case. both of those are 3-4 grand though depending on the options you choose. a dana 300 will also bolt in, but you'll either have to do a flip on it or switch to a passenger drop axle.
yeah, i had a typo on the sig. but i was thinkin of a d300 or diff pass side drop xfer cases when i did an axle swap. for the $$ what would be the best route to go, neglecting the drop? ive got access to quite a bit of chevy parts, what about 203, 205, or 208? how hard would they be?
203's and 205's will be harder to match up, not a bolt on deal. some 208's will work, but don't bother your 231 is as good. for the money, a 241 or a d300 is the way to go.
