ncgamedog
- Oct 30, 2005
- Greensboro, NC
I have OBA on my truck installed by the PO. It uses the factory AC compressor on my 3.4L. There is a manifold made of 2x2 square tube about 6-8" long that the pressure line feeds from the pump. It houses a pressure switch, pop-off valve, quick coupling, and gauge. It then feeds the tank mounted between the frame rails in the rear. The intake is simply the low side hose cut off with a valve cover breather mounted on the end. My truck had something draining the battery and i found that the pressure switch was doing it. Electrically, its fed from a factory fuse box on the pass side wheel well (91' PU) via a piggy back on a 15 amp fuse, then from the switch to a wire on the compressor to engage the magnet on the clutch. It was keeping the clutch on all the time thus causing the drain. The switch looks like any ole' pressure switch on a standard house-hold compressor, it has a lever on the side to turn it off but i could never tell that it worked. NOW my Question is this: Is the switch bad, or wired wrong? or is it that it is not made to work w/ the 12v system? or does that even matter? If so can i get a 12v switch and where?
Thanks so much - J
Thanks so much - J
