offroad axle brake line routing
ckruzer
Infidel
asheville nc
front and rear. can you guys show me how you routed yours?
Thanks!
No pics, but the front line goes down my upper control arm to a Y on top of the axle tube. That Y is secured via a 3/8"bolt welded to the tube. Then it splits to each caliper.
The rear is similar but having cutting brakes makes the plumbing a bit different. But typically I just run the rear supply hard line inside the frame to a flexible hose that drops down to the axle. Secure it just like the front is via a bolt welded to the tube. Then hard lines on top of the axle tube to the caliper flex hoses.
To secure to the axle tube, I usually just weld a thin (1/8") piece of 1" x 1" plate and then bend it over the line.
