ACCORDING TO GM, one quart of oil used in 1500 miles is NOT excessive oil usage.
This is their stance, especially since the LSx engines came out. If you go to ANY car manufacturer it will be some what similar, though we all know it's not right.
If the vehicle were under warranty, you would be given a work sheet to fill out with dates and mileage to cover oil comsumption. not until the usage reaches 1qt every 1500 mile will they even consider doing anything about it. As a former GM tech, I went rounds with customers about this, especially the owners of trucks with the 8100 engines.
I hated telling folks that, but what can I do ? I'm just the lucky stiff who got to try and figure it all out.
The 4.8, 5.3, 6.0 engines in the trucks are known for several things, piston slap and oil consumption being the most known complaints. intake leaks and valve spring issues being the next well known. In my experiance, the 6.0 seemd to have been the owrst offender, probably because they were worked harder than most.
The folks who have the pleasure of feeding an 8100 big block (496 cid NOT 502 cid) know they have intake gasket issues, crank position sensor failures, oil consupmtion issues, and a few other minor things.
a few things to check out on your engine, do a compresion test, hot and cold, if you find a low cyl, this could be your problem. a cyl leak down test may also be something you want to check out.
These engines do not pull a lot of vaccum, so a valve seal issue wouldn't present a smoke screen like an older engine would, also considering that the cats are probably burning a lot of it out as well.
these engines are also pretty well sealed up, so an external leak would be pretty easy to spot, and there is no path for oil other than the cyls, as the "valley" between the heads is sealed seperate from the intake, hell , ya have to pull the heads to swap the lifters should the need arise.
And just for grins, check out this site, pretty much covers some of the details
http://pistonslap.com/
May wanna read this as well
http://www.pistonslap.com/tsb/010601011A.pdf
ENjoy
