spykosshow
- Oct 13, 2005
- Raleigh, NC
Oil leak on 2001.5 ctd
I've got an oil leak on the 01 ctd 2500. I've cleaned it up underneath to try and figure out where it's leaking from. The only places I can see it coming from is from the bolts holding the oil pan onto the block.
I've been told I can use an engine hoist and lift the motor just enough to get the pan out. I have also seen that it is common for these motors to leak quickly after changing the gasket if they didn't use an rtv sealant at the same time.
Suggestions?
Also, does anyone have recommendations for shops that could tackle this in Raleigh?
Suggestions?
