Older Dodge lift kit help.
chromerunner
The Scrambler
Biscoe NC
I am trying to level out a older Dodge truck (1980 D200) It is 2WD.
Where can i buy new lift coils for the front? Im having a hard time finding any kit for the 2wd's. Thanks
I have a feeling there will be nothing out there...Your best bet is likely to measure them and find something with the same diameter and a similar spring rate, or to put rubber spring isolator spacers in for the lift.
I think your gonna have to piece some stuff together to get level it out. How much do you need to bring it up?
Also, are the shocks inside the springs on the front or off to the side? If not, you could put air bags inside the coils like the "air lift" setups, or air shocks inside the springs up front.
I have a D150 and from what I understand the coils from the 94 and up Rams are the same diameter and you could probably measure one up to find the lift you desire.
