- Apr 16, 2005
- Sharon, SC
All right I am getting the pieces together for this weeks on board air conversion. I have done this several times in the past all with Jeeps and York style compressors. This time its on a K5 with factory air and a Sandedn style comp.
I have most of the basics down from past experinece (IE definitely using an air tank, pressure relief valve, and hard wired toggle to engage clutch)
My question is with the non oiled compressor. I've read that you must use a preoiler and then a filter/separator and return, and I've also been told that as long as you run a few tablespoons of marvels mystery oil through every few months that there is no need for a constant oil supply.
Anyone have experience with the sanden style and no preoiler? How long has it been working? Any compressor issues?
Also in my research I have seen several people cutting the AC lines and using clamps to adapt to 3/8 air, where as in the past I've kept the full length AC lines and used threaded adapters to resive.. Any success with the clamps? Doesn't sem like it would hold up under 110 -135 psi IMHO
